RG-DEMUX(C)-24LC/LC |
RG-DEMUX-48LC/LC |
RG-MUX-48LC/LC |
Name |
48-port demultiplexer |
3 groups |
6 groups |
3 groups |
Installation location |
Core side |
Core side |
Building side |
24 |
48 |
48 |
Dimension (W × D × H) |
210.2 mm * 440 mm * 39.8 mm |
Item |
24-port demultiplexer, with three demultiplexing ports |
Center wavelength |
1271 nm to 1571 nm (CWDM) |
Channel spacing |
20 nm |
Channel bandwidth |
± 6.5 nm |
Insertion loss |
≤ 4 dB (demultiplexer and transparent multiplexer) |
Return loss |
> 45 dB |
Polarization dependent loss |
< 0.3 dB |
Adjacent channel isolation |
> 25 dB |
> 35 dB |
Connector |
LC/UPC |
–40°C to +85°C (–40°F to +185°F) (WDM products have no requirement for the altitude) |
10% to 90% RH |
5% to 90% RH |
Standards |
Net weight |
3.05 kg (6.72 lbs) |
Three groups |
24 |
Dimension (W x D x H) |
297.6 mm x 438.5 mm x 40.2 mm (11.72 in. x 17.26 in. x 1.58 in.) |
Item |
RG-DEMUX-48LC/LC |
48-port demultiplexer, with six demultiplexing ports |
Center wavelength |
Channel spacing |
20 nm |
Channel bandwidth |
± 6.5 nm |
Insertion loss |
Return loss |
> 45 dB |
< 0.3 dB |
> 25 dB |
> 35 dB |
Connector |
LC/UPC |
10% to 90% RH |
5% to 90% RH |
Standards |
Net weight |
3.49 kg (7.69 lbs) |
Six groups |
48 |
Item |
RG-MUX-48LC/LC |
48-port transparent multiplexer, with six demultiplexing ports |
Center wavelength |
Channel spacing |
20 nm |
Channel bandwidth |
± 6.5 nm |
Insertion loss |
Return loss |
> 45 dB |
< 0.3 dB |
> 25 dB |
> 35 dB |
Connector |
LC/UPC |
10% to 90% RH |
5% to 90% RH |
Standards |
Net weight |
3.01 kg (6.64 lbs) |
Three groups |
48 |
210.2 mm x 440 mm x 39.8 mm (8.28 in. x 17.32 in. x 1.57 in.) |
