RG-S7805C สวิตช์ - 1
RG-S7805C สวิตช์ - 2
RG-S7805C สวิตช์ - 3
RG-S7805C สวิตช์ - 4
RG-S7805C สวิตช์ - 5
RG-S7805C สวิตช์ - 6
RG-S7805C สวิตช์ - 7
RG-S7805C สวิตช์ - 8
RG-S7805C สวิตช์ - 9
Modular Core Switch RG-7805C
N+M Power Supply Redundancy
Hardware Specifications (Working with -CM Series Supervisor Module)
RG-S7805C
RG-S7808C
RG-S7810C
2 x supervisor module slots
3 x line card slots
1 x fan module slots
6 x line card slots
4 x power module slots
8 x line card slots (slot 7 does not support the EB line card.)
Supervisor module
M7805C-CM II
M7808C-CM II
M7810C-CM and M7810C-CM-F
Switch fabric module
Integrated with supervisor modules
M7810C-CM: M7810C-FE-D I
M7810C-CM-F: M7810C-FE-F I
line card
M7805C-CM II supports the following 9 modules (FA/FB series cannot be used with EB series or DA series):
● M7800C-48XS-FB
● M7800C-8CQ-FB
● M7800C-48GT-FA
● M7800C-48SFP-FA
● M7800C-32XS4QXS-DA
● M7800C-24GT24SFP4XS-EB
● M7800C-24SFP/12GT4XS-EB
● M7800C-48GT4XS-EB
● M7800C-48SFP4XS-EB
M7808C-CM II supports the following 9 modules (FA/FB series cannot be used with EB series or DA series):
● M7800C-48XS-FB
● M7800C-8CQ-FB
● M7800C-48GT-FA
● M7800C-48SFP-FA
● M7800C-48GT4XS-EB
M7810C-CM supports the following 5 modules (The modules cannot be used with FA series or FB series):
● M7800C-48GT4XS-EB
M7810C-CM-F supports the following 4 modules (The modules cannot be used with EB series or DA series):
● M7800C-48XS-FB
● M7800C-8CQ-FB
● M7800C-48GT-FA
● M7800C-48SFP-FA
RG-PA300I-F
RG-PA460I-F
RG-PA600I-F
RG-PA1600I-F
RG-PA600I
RG-PA1600I
M05C-FAN
M08-FAN
M10C-FAN
Supervisor module redundancy
Module management port
M7805C-CM II:
● 1 x RJ45 console port
● 1 x RJ45 MGMT port
M7808C-CM II:
M7810C-CM:
● M7810C-CM-F:
● 1 x RJ45 console port *
● 1 x mini USB console port *
* Note: Only one console port is allowed to be used at the same time.The mini USB console port has a higher priority.)
M7810C-CM: 1 x USB 2.0 port
M7810C-CM-F: 1 x USB 2.0 port
(no capacity limit, 2G/4G/8G/16G/32G capacity tested)?
RG-S7805C
RG-S7808C
RG-S7810C
System packet forwarding rate
4500 Mpps
9000 Mpps
12000 Mpps
6000 Gbps
12000 Gbps
16000 Gbps
Supervisor module:
Line card
Supervisor module:
Line card
Supervisor module:
Line card
M7805C-CM II: 1 GB
EB card: 512 MB
DA/FA/FB card: 8 GB
M7808C-CM II: 8 GB
EB card: 512 MB
DA/FA/FB card: 8 GB
M7810C-CM/M7810C-CM-F: 8 GB
EB card: 512 MB
DA/FA/FB card: 8 GB
M7810C-FE-D I: 8 GB
M7810C-FE-F I: 8 GB
M7805C-CM II: DDRIII 4 GB
EB card: DDRIII 1 GB
DA card: DDR4 1 GB
FA/FB card: DDR4 2 GB
M7808C-CM II: DDR4 4 GB
EB card: DDR3 1 GB
DA card: DDR4 1 GB
M7810C-CM/M7810C-CM-F: DDR4 4 GB
EB card: DDR3 1 GB
DA card: DDR4 1 GB
M7810C-FE-D I card: DDR4 1 GB
M7810C-FE-F I: DDR4 2 GB
EB: 4 MB
FB: 32 MB
FA: 8 MB
DA: 16 MB
EB: 4 MB
FB: 32 MB
FA: 8 MB
DA: 16 MB
EB: 4 MB
FB: 32 MB
FA: 8 MB
DA: 16 MB
RG-S7805C
RG-S7808C
RG-S7810C
4 x pluggable power modules
1+1 power redundancy (same model)
N+N power redundancy (same model)
RG-PA300I-F (AC input):
● Rated input voltage: 100 V AC to 240 V AC; 50 Hz to 60 Hz
RG-PA460I-F (AC input):
RG-PA600I-F (AC input):
RG-PA1600I-F (AC input):
● Maximum input current: 16 A
RG-PA600I (AC input):
RG-PA1600I (AC input):
RG-PA300I-F: 300 W
RG-PA460I-F: 460 W
RG-PA600I-F: 600 W
RG-PA1600I-F:
RG-PA600I: 600 W
RG-PA1600I:
Module power consumption
RG-S7805C: < 80 W
M7805C-CM II: < 21 W
M7800C-48XS-FB: < 160 W
M7800C-8CQ-FB: < 130 W
M7800C-48GT-FA: < 75 W
M7800C-48SFP-FA: < 95 W
M7800C-32XS4QXS-DA: < 210 W
M7800C-48GT4XS-EB: < 70 W
M7800C-48SFP4XS-EB: < 101 W
RG-S7808C: < 176 W
M7808C-CM II: < 50 W
RG-S7810C: < 432 W
M7810C-CM: < 50 W
M7810C-CM-F: < 110 W
RG-S7805C
RG-S7808C
RG-S7810C
442 mm x 465 mm x 441.7 mm (17.40 in. x 18.31 in. x 17.39 in.)
442.5 mm x 560 mm x 442 mm (17.42 in. x 22.05 in. x 17.40 in.)
4 RU
10 RU
10 RU
12.42 kg (27.38 lbs) (empty chassis and fan modules)
35.6 kg (78.48 lbs) (empty chassis and fan modules)
43.6 kg (96.01 lbs) (empty chassis and fan modules)
28.05 kg (61.84 lbs)
43.93 kg (96.85 lbs)
68.30 kg (150.58 lbs)
RG-S7805C
RG-S7808C
RG-S7810C
Storage altitude: 5,000 m (16,404.20 ft.) max
Operating altitude: 5,000 m (16,404.20 ft.) max
● Supervisor module: right-to-left airflow
● Service module: right-to-rear airflow
● Power module: built-in fan modules drawing air outward, front-to-rear airflow
● Supervisor module/Service module: right-to-rear airflow
● Power module: front-to-rear airflow
● Line card: side-to-rear airflow
● Supervisor module/FE card: front-to-rear airflow
27°C (80.6°F): 70 dB
Max Noise: 77 dB
Max Noise: 77 dB
Max Noise: 77 dB
Module hot swapping
Over-temperature alarming
Default settings:
Alarm temperature: The device generates alarms when the temperature of the air inlet is higher than 56°C (132.8°F). You can configure the alarm temperature.
Power-off temperature: By default, when the temperature of the CPU or media access controller (MAC) chip is higher than 100°C (212°F), the switch will be powered off. You can configure the power-off temperature. When the temperature is higher than 100°C (212°F) twice, the line cards will be powered off. The supervisor module will not be powered off.
Service port: 4 kV
RG-S7805C
RG-S7808C
RG-S7810C
European RoHS Directive 2011/65/EU & Amendment (EU) 2015/863
Hardware Specifications (Working with -X Series Supervisor Module)
RG-S7805C
RG-S7808C
RG-S7810C-X
3 x line card slots
6 x line card slots
8 x line card slots
Supervisor module
M7805C-CM-X
M7808C-CM-X
M7810C-CM-X
M7810C-FE-X I
M7810C-FE-X II
line card
M7800C-48GT4XS-XA
M7800C-48SFP4XS-XA
M7800C-24GT8SFP8XS-XA
M7800C-52XS-XB
M7800C-12CQ-XB
M7800C-32XS-XA
M7800C-48XT-P-XB
M7800C-48GT4XS-XA
M7800C-48SFP4XS-XA
M7800C-52XS-XB
M7800C-12CQ-XB
M7800C-32XS-XA
M7800C-48XT-P-XB
M7800C-8SFG-XB
M7800C-8SFX-XB
M7800C-48GT4XS-XA
M7800C-48SFP4XS-XA
M7800C-52XS-XB
M7800C-12CQ-XB
M7800C-32XS-XA
M7800C-48XT-P-XB
M7800C-8SFG-XB
M7800C-8SFX-XB
RG-PA300I-F
RG-PA460I-F
RG-PA1600I-PL
RG-PA600I-F
RG-PA1600I-F
RG-PA1600I-PL
RG-PA600I
RG-PA1600I
RG-PD600I
RG-PA1600I-PL
M05C-FAN
M08-FAN
M10C-FAN
M7805C-CM-X:
M7808C-CM-X:
M7810C-CM-X:
SD
RG-S7805C
RG-S7808C
RG-S7810C-X
4500 Mpps
9000 Mpps
14300 Mpps
6000 Gbps
12000 Gbps
19200 Gbps
Supervisor module:
M7805C-CM-X: 2.2 GHz quad-core processor, each core 2.2 GHz
Line card:
XA/XB series line card: 2.2 GHz quad-core processor, each core 2.2 GHz
Supervisor module:
M7808C-CM-X: quad-core processor, each core 2.2 GHz
Line card:
XA/XB series line card: quad-core processor, each core 2.2 GHz
Supervisor module:
M7810C-CM-X: quad-core processor, each core 2.2 GHz
Line card:
M7805C-CM-X: 8 GB
XA/XB card: 8 GB
M7808C-CM-X: 8 GB
XA/XB card: 8 GB
M7810C-CM-X: 8 GB
XA/XB card: 8 GB
M7805C-CM-X: DDR4 4 GB
XA/XB card: DDR4 4 GB
M7808C-CM-X: DDR4 4 GB
M7810C-CM-X: DDR4 4 GB
XB series line card: 35 MB
M7800C-32XS-XA: 35 MB
RG-S7805C
RG-S7808C
RG-S7810C-X
RG-PA1600I-PL (AC input):
RG-PD600I (DC input):
● Maximum input current: 20 A
RG-PA300I-F: 300 W
RG-PA460I-F: 460 W
RG-PA600I-F: 600 W
RG-PA1600I-F:
RG-PA600I: 600 W
RG-PA1600I:
RG-PD600I:600 W
RG-S7805C: < 80 W
M7805C-CM-X:< 40 W
M7800C-12CQ-XB:< 240 W
M7800C-24GT8SFP8XS-XA:< 95 W
M7800C-32XS-XA:< 149 W
M7800C-48XT-P-XB:< 300 W
M7800C-48GT4XS-XA:< 85 W
M7800C-48SFP4XS-XA:< 117 W
M7800C-52XS-XB:< 250 W
RG-S7808C: < 176 W
M7808C-CM-X:< 62 W
M7800C-8SFG-XB:< 250 W
M7800C-8SFX-XB:< 250 W
RG-S7810C:-X < 432 W
M7810C-CM-X:< 60 W
M7810C-FE-X I:< 50 W
M7810C-FE-X II:< 160 W
RG-S7805C
RG-S7808C
RG-S7810C-X
4 RU
10 RU
10 RU
43.55 kg (96.01 lbs) (empty chassis and fan modules)
RG-S7805C
RG-S7808C
RG-S7810C-X
Supervisor module: air intake from the right and exhaust from back Service module: air intake from the right and exhaust from back System power module: drawing air outward with built-in fans, air intake from the front panel and exhaust from back
Supervisor module /Service module: air intake from the right and exhaust from back, drawing air outward to form convection for heat dissipation System power module: air intake from the front panel and exhaust from back, drawing air inward to form convection for heat dissipation
Line card: air intake from the side and exhaust from back Supervisor module/Switch fabric module: air intake from the front panel and exhaust from back
Max Noise: 77 dB
Max Noise: 77 dB
Max Noise: 77 dB
Module hot swapping
1. Monitoring of the model, temperature, power, and voltage of the power supply module
2. Power failure alarms
3. Control of line card power-on based on the power status
Fan failure alarms
Over-temperature warning
Default settings:
Warning temperature: The device logs alarms when the temperature of the air inlet is higher than 56°C (132.8°F). You can configure the warning temperature.
Power-off temperature: By default, when the temperature of the CPU or media access controller (MAC) chip is higher than 100°C (212°F), the device will be powered off. You can configure the power-off temperature. When the temperature is higher than 100°C (212°F) twice, the line cards will be powered off. The supervisor module will not be powered off.
Service port: 4 kV
RG-S7805C
RG-S7808C
RG-S7810C-X
Software Specifications (Working with -CM Series Supervisor Module)
IPv4/IPv6 IS-IS
EVPN
Policy-based routing (PBR)
IPv4 and IPv6 ECMP
IGMP snooping v1/v2/v3
MLD v1/v2 snooping
MPLS IPv6
MPLS 6VPE
Port-based rate limiting
802.1p
CAR
VRRP for the super-VLAN
SPAN, RSPAN, and ERSPAN
FTP, TFTP, and Xmodem
Web-based NMS
Software Specifications (Working with -X Series Supervisor Module)
RG-S7805C
RG-S7808C
RG-S7810C-X
protocol-based VLAN
Super-VLAN
STP (IEEE 802.1.d)
RSTP (IEEE 802.1w)
MSTP (IEEE 802.1s)
OpenFlow 1.3
DHCPv6 client
DHCPv6 relay
FTP Server
FTP Client
NTP server
NTP Client
SNTP Client
TFTP Client
TFTP Server
BGP4
BGP4+
IS-ISv4
IS-ISv6
OSPFv3
RIP
RIPng
Routing Policy
PIM-DM
PIM-SM
MLD v1/v2 snooping
MPLS 6VPE
MPLS IPv6
MPLS forwarding
LDP
LSP
VXLAN Layer 2 bridge
VXLAN Layer 3 gateway
Standard IP ACL
extended IP ACL
extended MAC ACL
Layer 2 and Layer 3 port ACL
VLAN ACL
Expert-level ACL
ACL COUNTER
ACL LOGGING
ACL REMARK
802.1P
SP
WRR
SP+WFR
RED/WRED
MPLS QOS
1+1 fan redundancy
VRRP+
Faulty optical port isolation
port security
RADIUS
SSHv2
IPv6 SAVI
SNMP V1/V2c/V3
RMON
GRPC
SPAN
ERSPAN
VLAN mirroring
Web-based NMS
Energy-Saving Design
RG-S7805C
RG-S7808C
RG-S7810C
RG-S7810C-X
M7805C-CM II
M7808C-CM II
M7810C-CM
M7810C-CM-F
M7805C-CM-X
M7808C-CM-X
M7810C-CM-X
Notes:
Mandatory item, 1+1 redundancy supported, and at least one supervisor module must be configured.
Power Modules and Fan Modules
RG-PA300I-F
RG-PA460I-F
RG-PA600I-F
RG-PA1000I-F
RG-PA1600I-F
RG-PA600I
RG-PA1600I
RG-PD600I
M78-PSE-X
PoE power chassis, used together with RG-PA1600I-PL (Working with -X series supervisor module. If the PoE function is used, you need to separately configure the PoE power chassis M78-PSE-XL and the power module RG-PA1600I-P for M7800C-48XT-P-XB.)
RG-PA1600I-PL
PoE power module (available for redundancy, AC, 1600 W, 16 A) used together with M78-PSE-X (Working with -X series supervisor module. If the PoE function is used, you need to separately configure the PoE power chassis M78-PSE-X and the power module RG-PA1600I-P for M7800C-48XT-P-XB.)
Switch Fabric Modules
M7810C-FE-D I
M7810C-FE-F I
M7810C-FE-X I
M7810C-FE-X II
M7800C-48XS-FB
M7800C-8CQ-FB
M7800C-48GT-FA
48 x GE RJ45 ports
M7800C-48SFP-FA
M7800C-32XS4QXS-DA
M7800C-48GT4XS-EB
M7800C-48SFP4XS-EB
M7800C-32XS-XA
M7800C-48GT4XS-XA
M7800C-48SFP4XS-XA
M7800C-52XS-XB
M7800C-12CQ-XB
M7800C-48XT-P-XB
48 x 100M/GE/2.5GE/5GE/10GE electrical ports (RJ45 and PoE/PoE+. If the PoE function is used, you need to separately configure the PoE power chassis M78-PSE-X and the power module RG-PA1600I-P for M7800C-48XT-P-XB.)
M7800C-8SFG-XB
M7800C-8SFX-XB
Notes:
