RG-S7810C-X สวิตช์ - 1
RG-S7810C-X สวิตช์ - 2
RG-S7810C-X สวิตช์ - 3
RG-S7810C-X สวิตช์ - 4
8 x line card slots
M7800C-8SFG-XB
  • 8 GE SFG ports
M7800C-8SFX-XB
1+1
Supervisor Engine Redundancy
N+M
Power Supply Redundancy
N+M Power Supply Redundancy
1+1 Fan Module Redundancy
1+1
Hardware Specifications (Working with -CM Series Supervisor Module)
RG-S7805C
RG-S7808C
RG-S7810C
2 x supervisor module slots
3 x line card slots
1 x fan module slots
6 x line card slots
4 x power module slots
8 x line card slots (Slot 7 does not support the EB line card.)
Supervisor module
M7805C-CM II
M7808C-CM II
M7810C-CM and M7810C-CM-F
Switch fabric module
Built-in
Integrated with supervisor modules
M7810C-CM: M7810C-FE-D I
M7810C-CM-F: M7810C-FE-F I
RG-PA300I-F
RG-PA460I-F
RG-PA600I-F
RG-PA1600I-F
RG-PA600I
RG-PA1600I
M05C-FAN
M08-FAN
M10C-FAN
Line card
M7805C-CM II supports the following 9 modules (FA/FB series cannot be used with EB series or DA series):
● M7800C-48XS-FB
● M7800C-8CQ-FB
● M7800C-48GT-FA
● M7800C-48SFP-FA
● M7800C-32XS4QXS-DA
● M7800C-24GT24SFP4XS-EB
● M7800C-24SFP/12GT4XS-EB
● M7800C-48GT4XS-EB
● M7800C-48SFP4XS-EB
M7808C-CM II supports the following 9 modules (FA/FB series cannot be used with EB series or DA series):
● M7800C-48XS-FB
● M7800C-8CQ-FB
● M7800C-48GT-FA
● M7800C-48SFP-FA
● M7800C-48GT4XS-EB
M7810C-CM supports the following 5 modules (The modules cannot be used with FA series or FB series):
● M7800C-48GT4XS-EB
M7810C-CM-F supports the following 4 modules (The modules cannot be used with EB series or DA series):
● M7800C-48XS-FB
● M7800C-8CQ-FB
● M7800C-48GT-FA
● M7800C-48SFP-FA
Supervisor module redundancy
Module management port
Supervisor module:
● 1 x MGMT port
● 1 x console port
Supervisor module:
● 1 x MGMT port
● 1 x console port
Supervisor module:
● 1 x MGMT port
● 1 x console port
Supervisor module: 1 x USB 2.0 port (no capacity limit, 2G/4G/8G/16G/32G capacity tested)
Module hot swapping
RG-S7805C
RG-S7808C
RG-S7810C
System packet forwarding rate  *1
4,500 Mpps
9,000 Mpps
12,000 Mpps
6 Tbps
12 Tbps
16 Tbps
EB: 4 MB
FB: 32 MB
FA: 8 MB
DA: 16 MB
EB: 4 MB
FB: 32 MB
FA: 8 MB
DA: 16 MB
EB: 4 MB
FB: 32 MB
FA: 8 MB
DA: 16 MB
Supervisor module
● M7805C-CM II: 1.0 GHz quad-core CPU
Line card
● EB card: 1.0 GHz quad-core CPU
● DA/FA/FB card: 1.5 GHz quad-core CPU
Supervisor module
● M7808C-CM II: 1.5 GHz quad-core CPU
Line card
Supervisor module
● M7810C-CM/M7810C-CM-F: 1.5 GHz quad-core CPU
Line card
● M7810C-FE-D I/M7810C-FE-F I: 1.5 GHz quad-core CPU
M7805C-CM II: 1 GB
EB card: 512 MB
DA/FA/FB card: 8 GB
M7808C-CM II: 8 GB
EB card: 512 MB
DA/FA/FB card: 8 GB
M7810C-CM/M7810C-CM-F: 8 GB
EB card: 512 MB
DA/FA/FB card: 8 GB
M7810C-FE-D I: 8 GB
M7810C-FE-F I: 8 GB
M7805C-CM II: DDRIII 4 GB
EB card: DDRIII 1 GB
DA card: DDR4 1 GB
FA/FB card: DDR4 2 GB
M7808C-CM II: DDR4 4 GB
EB card: DDR3 1 GB
DA card: DDR4 1 GB
M7810C-CM/M7810C-CM-F: DDR4 4 GB
EB card: DDR3 1 GB
DA card: DDR4 1 GB
M7810C-FE-D I card: DDR4 1 GB
M7810C-FE-F I: DDR4 2 GB
● EB card: 64,000
● DA card: 96,000 (default) and 288,000 (max.)
● FA card: 80,000
● FB card: 96,000
● EB card: 4,000
● DA card: 10,000
● FA card: 4,000
● FB card: 40,000
EB card: 8,000
DA card: 16,000
FA card: 8,000
FB card: 16,000
EB card: 4,000
DA card: 8,000
FA card: 4,000
FB card: 8,000
Ingress
● EB card: 3,500
● DA card: 8,000
● FA card: 5,000
● FB card: 4,500
Egress
● EB card: 1,000
● DA card: 1,000
● FA card: 1,000
● FB card: 2,000
RG-S7805C
RG-S7808C
RG-S7810C
442.5 mm x 560 mm x 442 mm (17.42 in. x 22.05 in. x 17.40 in.)
4 RU
10 RU
10 RU
12.42 kg (27.38 lbs)
(empty chassis and fan modules)
35.6 kg (78.48 lbs)
43.6 kg (96.12 lbs)
Weight of power module
RG-PA300I-F: 0.85 kg (1.87 lbs)
RG-PA460I-F: 0.9 kg (1.98 lbs)
RG-PA600I-F: 1.64 kg (3.62 lbs)
RG-PA1600I-F: 2.04 kg (4.50 lbs)
RG-PA600I: 1.64 kg (3.62 lbs)
RG-PA1600I: 2.04 kg (4.50 lbs)
Weight of fan module
M05C-FAN: 1.65 kg (3.64 lbs)
M08-FAN: 1.65 kg (3.64 lbs)
M10C-FAN: 2.5 kg (5.51 lbs)
Module weight
Supervisor module:
M7805C-CM II: 0.86 kg (1.90 lbs)
Line card:
M7800C-48XS-FB: 3.85 kg (8.49 lbs)
M7800C-8CQ-FB: 3.50 kg (7.72 lbs)
M7800C-48GT-FA: 3.10 kg (6.83 lbs)
M7800C-48SFP-FA: 3.20 kg (7.05 lbs)
M7800C-32XS4QXS-DA: 3.40 kg (7.50 lbs)
M7800C-24GT24SFP4XS-EB: 2.85 kg (6.28 lbs)
M7800C-24SFP/12GT4XS-EB: 2.95 kg (6.50 lbs)
M7800C-48GT4XS-EB: 2.85 kg (6.28 lbs)
M7800C-48SFP4XS-EB: 3.10 kg (6.83 lbs)
Supervisor module:
M7808C-CM II: 2.10 kg (4.63 lbs)
Line card:
Supervisor module:
M7810C-CM: 1.95 kg (4.30 lbs)
M7810C-CM-F: 2.30 kg (5.07 lbs)
Line card:
Switch fabric module:
M7810C-FE-D: 1.95 kg (4.30 lbs)
M7810C-FE-F: 2.25 kg (4.96 lbs)
RG-S7805C
RG-S7808C
RG-S7810C
RG-PA300I-F (AC input):
● Rated voltage: 100 V AC to 120 V AC, 200 V AC to 240 V AC; 50 Hz to 60 Hz
● Maximum voltage: 90 V AC to 264 V AC; 47 Hz to 63 Hz
RG-PA460I-F (AC input):
● Maximum voltage: 90 V AC to 290 V AC; 45 Hz to 65 Hz
RG-PA600I-F (AC input):
RG-PA1600I-F (AC input):
RG-PA600I (AC input):
RG-PA300I-F: 300 W
RG-PA460I-F: 460 W
RG-PA600I-F: 600 W
RG-PA1600I-F:
● 90 V AC to 180 V AC: 12,00 W
● 180 V AC to 264 V AC: 1,600 W
RG-PA600I: 600 W
RG-PA1600I:
● 90 V AC to 180 V AC: 1,200 W
Module power consumption
Chassis RG-S7805C: < 80 W
Supervisor module: M7805C-CM II: < 21 W
Service module:
M7800C-48XS-FB: < 160 W
M7800C-8CQ-FB: < 130 W
M7800C-48GT-FA: < 75 W
M7800C-48SFP-FA: < 95 W
M7800C-32XS4QXS-DA: < 210 W
M7800C-48GT4XS-EB: < 70 W
M7800C-48SFP4XS-EB: < 101 W
Chassis RG-S7808C: < 176 W
Supervisor module: M7808C-CM II: < 50 W
Service module:
Chassis RG-S7810C: < 432 W
Supervisor module:
M7810C-CM: < 50 W
M7810C-CM-F: < 110 W
Service module:
RG-S7805C
RG-S7808C
RG-S7810C
Storage altitude: 5,000 m (16,404.20 ft.) max
Operating altitude: 5,000 m (16,404.20 ft.) max
216,000 hours (24 years)
342,000 hours (39 years)
Service module: right-to-rear airflow
Supervisor module/Service module: right-to-rear airflow
Supervisor module/FE card: front-to-rear airflow
70 dB at normal temperature
Max Noise: 77dB
Max Noise: 77dB
Max Noise: 77dB
Over-temperature alarming
Default settings:
Alarm temperature: The device generates alarms when the temperature of the air inlet is higher than 56°C (132.8°F). You can configure the alarm temperature.
Power-off temperature: By default, when the temperature of the CPU or media access controller (MAC) chip is higher than 100°C (212°F), the switch will be powered off. You can configure the power-off temperature. When the temperature is higher than 100°C (212°F) twice, the line cards will be powered off. The supervisor module will not be powered off.
IP rating
IP31, no dust filters for factory delivery
Seismic level
8 degrees
8 degrees
8 degrees
Ethernt port: common mode 4 kV, differential mode 1 kV
Service port: 4 kV
Service port: 4 kV
RG-S7805C
RG-S7808C
RG-S7810C
GB 4943.1
GB/T 9254.1
Hardware Specifications (Working with -X Series Supervisor Module)
RG-S7805C
RG-S7808C
RG-S7810C-X
Supervisor module slot
Line card slot
Switch fabric module slot
6 Tbps
12 Tbps
19.2 Tbps
4500 Mpps
9000 Mpps
14300 Mpps
 M7800C-8SFX-XB: 256000
 M7800C-8SFG-XB: 256000
 XA card: 96000
 XB card: 256000
 M7800C-8SFX-XB: 9600
 M7800C-8SFG-XB: 9600
 XA card: 4000
 XB card: 9600
 M7800C-8SFX-XB: 350000 (shared with IPv4 routes)
 M7800C-8SFG-XB:350000 (shared with IPv4 routes)
 XA card:64000 (shared with IPv4 routes)
 XB card: 350000 (shared with IPv4 routes)
4000
 M7800C-8SFX-XB: 65000 (shared with IPv4 routes)
 M7800C-8SFG-XB:15000 (shared with IPv4 routes)
 XA card: 65000 (shared with IPv4 routes)
 XB card: 65000 (shared with IPv4 routes)
2000
 Ingress
M7800C-8SFX-XB: 2800
M7800C-8SFG-XB: 2800
XA card: 7000
XB card: 2800
 Egress
M7800C-8SFX-XB: 4000
M7800C-8SFG-XB: 4000
XA card: 1500
XB card: 4000
442 mm × 451 mm × 175 mm (17.40 in. x 17.76 in. x 6.89 in.)
442 mm × 465 mm × 441.7 mm (17.40 in. x 18.31 in. x 17.39 in.)
442.5 mm × 560 mm × 442 mm (17.42 in. x 22.05 in. x 17.40 in.)
32.35 kg
35.6 kg
43.55 kg
Rack Size
4 RU
10 RU
10 RU
2.2 GHz quad-core processor
Flash Memory:8 GB
SDRAM:DDR4 4 GB
Flash Memory:8 GB
SDRAM:DDR4 4 GB
Flash Memory:8 GB
SDRAM:DDR4 4 GB
Max. Output Power
 RG-PA300I-F:
90 V AC to 180 V AC; Power: 300 W
180 V AC to 264 V AC; Power: 300 W
 RG-PA460I-F:
90 V AC to 180 V AC; Power: 460 W
180 V AC to 264 V AC; Power: 460 W
 RG-PA1000I-F:
90 V AC to 176 V AC; Power: 800 W
176 V AC to 264 V AC; Power: 1000 W
 RG-PA600I-F:
90 V AC to 180 V AC; Power: 600 W
180 V AC to 264 V AC; Power: 600 W
 RG-PA1600I-F:
90 V AC to 180 V AC; Power: 1200 W
180 V AC to 264 V AC; Power: 1600 W
 RG-PA1600I:
 RG-PA600I:
 RG-PD600I:
–40 V DC to –75 V DC; Power: 600 W
 RG-PA1600I-PL:
90 V AC to 176 V AC; Power: 1200 W
176 V AC to 264 V AC; Power: 1600 W
 M7805C-CM-X:< 40 W
 M7800C-12CQ-XB:< 240 W
 M7800C-24GT8SFP8XS-XA:< 95 W
 M7800C-32XS-XA:< 149 W
 M7800C-48XT-P-XB:< 300 W
 M7800C-48GT4XS-XA:< 85 W
 M7800C-48SFP4XS-XA:< 117 W
 M7800C-52XS-XB:< 250 W
 M7800C-8SFG-XB:< 250 W
 M7800C-8SFX-XB:< 250 W
 M7808C-CM-X:< 62 W
 M7810C-CM-X:< 60 W
 M7810C-FE-X I:< 50 W
 M7810C-FE-X II:< 160 W
 Supervisor module: air intake from the right and exhaust from back
 Service module: air intake from the right and exhaust from back
 System power module: drawing air outward with built-in fans, air intake from the front panel and exhaust from back
 Supervisor module /Service module: air intake from the right and exhaust from back, drawing air outward to form convection for heat dissipation
 System power module: air intake from the front panel and exhaust from back, drawing air inward to form convection for heat dissipation
 Line card: air intake from the side and exhaust from back
 Supervisor module/Switch fabric module: air intake from the front panel and exhaust from back
5% to 95% RH
–500 m to +5000 m (–1,640.41 ft. to +16,404.20 ft.)
Surge Protection of Communication Ports
6 kV
Software Specifications (Working with -CM Series Supervisor Module)
IPv4/IPv6 IS-IS
EVPN
Policy-based routing (PBR)
IPv4 and IPv6 ECMP
IGMP snooping v1/v2/v3
MLD v1/v2 snooping
MPLS IPv6
MPLS 6VPE
Port-based rate limiting
802.1p
CAR
VRRP for the super-VLAN
SPAN, RSPAN, and ERSPAN
FTP, TFTP, and Xmodem
Web-based NMS
Software Specifications (Working with -X Series Supervisor Module)
RG-S7805C
RG-S7808C
RG-S7810C-X
protocol-based VLAN
Super-VLAN
STP (IEEE 802.1.d)
RSTP (IEEE 802.1w)
MSTP (IEEE 802.1s)
OpenFlow 1.3
DHCPv6 client
DHCPv6 relay
FTP Server
FTP Client
NTP server
NTP Client
SNTP Client
TFTP Client
TFTP Server
BGP4
BGP4+
IS-ISv4
IS-ISv6
OSPFv3
RIP
RIPng
Routing Policy
PIM-DM
PIM-SM
MLD v1/v2 snooping
MPLS 6VPE
MPLS IPv6
MPLS forwarding
LDP
LSP
VXLAN Layer 2 bridge
VXLAN Layer 3 gateway
Standard IP ACL
extended IP ACL
extended MAC ACL
Layer 2 and Layer 3 port ACL
VLAN ACL
Expert-level ACL
ACL COUNTER
ACL LOGGING
ACL REMARK
802.1P
SP
WRR
SP+WFR
RED/WRED
MPLS QOS
1+1 fan redundancy
VRRP+
Faulty optical port isolation
port security
RADIUS
SSHv2
IPv6 SAVI
SNMP V1/V2c/V3
RMON
GRPC
SPAN
ERSPAN
VLAN mirroring
Web-based NMS
Energy-Saving Design
RG-S7805C
RG-S7805C switch, which can accommodate three line cards and two supervisor modules (supporting -CM series and -X series supervisor modules)
RG-S7808C
RG-S7808C switch, which can accommodate six line cards and two supervisor modules (supporting -CM series and -X series supervisor modules)
RG-S7810C
RG-S7810C switch, which can accommodate eight service cards, two supervisor modules, and two switch fabric modules (supporting -CM series supervisor modules)
RG-S7810C-X
RG-S7810C-X switch, which can accommodate eight line cards, two supervisor modules, and four switch fabric modules (supporting -X series supervisor modules)
M7805C-CM II
M7808C-CM II
M7810C-CM
M7810C-CM-F
M7805C-CM-X
M7808C-CM-X
M7810C-CM-X
Notes:
Power Modules and Fan Modules
RG-PA300I-F
RG-PA460I-F
RG-PA600I-F
RG-PA1000I-F
RG-PA1600I-F
RG-PA600I
RG-PA1600I
RG-PD600I
M78-PSE-X
PoE power chassis, used together with RG-PA1600I-PL (Working with -X series supervisor module. If the PoE function is used, you need to separately configure the PoE power chassis M78-PSE-XL and the power module RG-PA1600I-P for M7800C-48XT-P-XB.)
RG-PA1600I-PL
PoE power module (available for redundancy, AC, 1600 W, 16 A)  used together with M78-PSE-X (Working with -X series supervisor module. If the PoE function is used, you need to separately configure the PoE power chassis M78-PSE-XL and the power module RG-PA1600I-P for M7800C-48XT-P-XB.))
RG-PA3000I-PL
PoE power module (available for redundancy, AC, 3000 W, 16 A)  used together with M78-PSE-X (Working with -X series supervisor module. If the PoE function is used, you need to separately configure the PoE power chassis M78-PSE-XL and the power module RG-PA1600I-P for M7800C-48XT-P-XB.)
Switch Fabric Modules
M7810C-FE-D I
M7810C-FE-F I
M7810C-FE-X I
M7810C-FE-X II
M7800C-48XS-FB
M7800C-8CQ-FB
M7800C-48GT-FA
48 x GE RJ45 ports
M7800C-48SFP-FA
M7800C-32XS4QXS-DA
M7800C-48GT4XS-EB
M7800C-48SFP4XS-EB
M7800C-32XS-XA
M7800C-48GT4XS-XA
M7800C-48SFP4XS-XA
M7800C-52XS-XB
M7800C-12CQ-XB
M7800C-48XT-P-XB
48 x 100M/GE/2.5GE/5GE/10GE electrical ports (RJ45 and PoE/PoE+)
M7800C-8SFG-XB
M7800C-8SFX-XB
Notes:
EB series line card only interchanged with D series line cards.
D series line card only interchanged with EB series line cards.
F series line card cannot be interchanged with other line cards.
