RG-S6910-3C สวิตช์ - 1
RG-S6910-3C สวิตช์ - 2
RG-S6910-3C สวิตช์ - 3
RG-S6910-3C สวิตช์ - 4
RG-S6910-3C สวิตช์ - 5
RG-S6910-3C สวิตช์ - 6
RG-S6910-3C สวิตช์ - 7
RG-S6910-3C สวิตช์ - 8
RG-S6910-3C
100GE/400GbE ports
Slots
Expansion Module Slots
Four power module slots
Six fan module slots
19.2 Tbps
4000 Mpps
4094
(W × D × H)
AC
High-voltage DC
Maximum Power Consumption
● Max: 2046 W
● Typical: 1092 W
● Static: 760 W
Working altitude
RG-S6910-3C
Docker
gRPC APIs in Docker
L2 Protocols
L3 Protocols (IPv4)
IPv6 Basic Protocols
sFLOW and IPFIX
Data center features
Flow Suspension Prevention
MMU
Real-Time Buffer Monitoring
HA Design
Security Features
Management Mode
Specification
RG-S6910-3C
● UL 62368-1
● CSA C22.2 No. 62368-1
● BS EN 62368-1
● EN 61000-3-2
● BS EN55032
● BS EN 55035
● BS EN 61000-3-2
● BS EN61000-3-3
● EN 300 386
● ANSI C63.4
● ICES-003 Issue 7
RG-S6910-3C
M6900-32CQ
32-port 100GbE card
RG-PA1200I-F
M2EFAN I-F
