RG-N18010-XH สวิตช์ - 1
RG-N18010-XH สวิตช์ - 2
RG-N18010-XH สวิตช์ - 3
RG-N18010-XH สวิตช์ - 4
RG-N18010-XH สวิตช์ - 5
RG-N18010-XH สวิตช์ - 6
RG-N18010-XH สวิตช์ - 7
RG-N18010-XH สวิตช์ - 8
RG-N18010-XH สวิตช์ - 9
RG-N18010-XH สวิตช์ - 10
RG-N18010-XH – Next Generation Data Center Network High-Density Centralized Modular Core Switch with 100GE/400GE Line Cards and Eight Service Slots
  • 100GE and 400GE line cards, and up to 288 x 400GE and 1152 x 100GE line-rate ports
  • Innovative technology design and efficient heat dissipation, with more than 50,000 kWh saved per device each year
Data Center 400GE Modular
Core Switch
RG-N18010-XH
The RG-N18010-XH provides 10 module
slots, including eight service slots, which can
be used with 100GE and 400GE line cards. It
supports 800GE line cards in the future,
easily coping with future bandwidth
expansion needs.
With various port types, the RG-N18010-XH
supports up to 288 x 400GE and 1152 x
100GE line-rate ports, and allows smooth
evolution to 800GE, satisfying requirements
in diversified scenarios of data center
networks.
Innovative Architecture Design,
Achieving Highly Efficient Data Transmission
Zero Midplane
Clos Architecture
Communication at the Maximum Distance of 120 KM and Easy DCI
Hardware-level Redundancy,
Ensuring Nonstop Services and Data
Center Network Stability
SFUs in N+1 Redundancy Mode
SFUs use N+1 redundancy and work in load balancing
mode, ensuring nonstop services.
Power Modules in M+N Redundancy Mode
Ten hot-swappable power modules are available. When a
fault occurs, services are switched within seconds. Services
are not interrupted when a power module is replaced. The
switch provides different protection measures for links.
Fan Trays in 2+1 Redundancy Mode
Three hot-swappable fan trays are available. The speed of
fan modules can be intelligently adjusted, ensuring highly
efficient heat dissipation.
Supervisor Engin es in 1+1 Redundancy Mode
The 1+1 hot standby design ensure continuous operation of
the switch.
Innovative Technology Design and Highly Efficient Heat Dissipation
With MACsec, the switch achieves interface-based secure line-rate transmission, effectively preventing data from being intercepted and obtained maliciously
and ensuring service data security.
RG-N18010-XH
645 Tbps/1,935 Tbps
345,600 Mpps
Slots
Module Slots
10 (2 for supervisor modules)
Switch Fabric Module Slots
Three fan module slots
Ten power module slots
Without cable management brackets: 442 mm x 896 mm x 708 mm (17.40 in. x 35.28 in. x 27.87 in., 16 RU)
With cable management brackets: 442 mm x 935 mm x 708 mm (17.40 in. x 36.81 in. x 27.87 in., 16 RU)
96.4 kg (212.53 lbs., including the fan)
RG-PAH3000I-F:
● AC: 100 V AC to 176 V AC, power: 1,500 W
● AC: 176 V AC to 240 V AC, power: 3,000 W
● HVDC: 240 V DC to 380 V DC, power consumption: 3,000 W
Airflow direction
Front-to-rear
Maximum Power Consumption
18,760 W
312,683 hours
● Operating altitude for long-term working conditions: up to 5000 m (16404.20 ft.). At 1800 m (5905.51 ft.), the maximum operating temperature is 40°C (104°F). The maximum operating temperature decreases by 1°C (1.8°F) per 200 m (656.16 ft.) increase in altitude.
● Operating altitude: up to 5,000 m (16404.20 ft.)
● Storage altitude: up to 5,000 m (16404.20 ft.)
RG-N18010-XH
Traffic Analysis
IPFIX
Layer 2 Features
IEEE 802.1Q
STP, RSTP, MSTP
Policy-based routing
Manual tunnel and GRE tunnel
VRRPv3
Path MTU Discovery
Pingv6, telnetv6, FTPv6, TFTPv6, DNSv6, ICMPv6
IGMP snooping
MLDv1, MLDv2
Fast leave
MPLS LDP
#SR MPLS (Segment Routing)
#SR-TE
Ingress and egress ACLs
IPv6 ACLs
Multiple queue scheduling mechanisms, including SP(PQ), DRR, SP(PQ) + DRR, WFQ, SP(PQ) + WFR,
Ingress and egress rate limiting, CAR
#MPLS QoS
Data center features
#SRv6
VXLAN bridge
VXLAN gateway
BGP-EVPN VXLAN
VXLAN mapping
IPv6 VXLAN over IPv4
MLAG
OpenFlow 1.3.
Independent switch fabric modules and independent supervisor modules to implement thorough separation of the forwarding plane from the control plane
N+M redundancy for power modules and fans
Backplane-free design to avoid single point of failures
Hot patch function and online installation of patches
BPDU Guard/Loop Guard/Root Guard
NSR
FRR
Virtual Switching Unit 3.0
MACSec
Network Foundation Protection Policy (NFPP) and CPU protection policy (CPP) to prevent protocol packet attacks
DAI, port security, IP source guard, and port protection
Source IP address restriction
FTP, TFTP, Xmodem, and SFTP SNMP V1/V2c/V3
RMON
NTP clock
Traffic analysis
Zero-touch provisioning (ZTP)
Telemetry
Monitoring of fan modules and power modules
* indicates that the feature will be available in the future.
# indicates that the feature is supported by only CE cards.
RG-N18010-XH
● EN IEC 62368-1
● EN 300 386 V2.2.1
RG-N18010-XH
RG-N18010-XH chassis, excluding power modules, with all fans
M18000XH-CM
M18000XH-CM supervisor module
Power Modules
RG-PAH3000I-F
3000 W AC power module (AC and 240 V to 380 V HVDC)
Switch Fabric Modules
M18018XH-FE-E IV
Type-E switch fabric module II for RG-N18010-XH, used together with CE cards
M18010XH-FE-E II
M18000XH-36QC-CES
Line card with 36 x 400GE QSFP-DD ports, used together with Type-E switch fabric modules
M18000XH-48CQ-CES
Line card with 48 x 100GE QSFP28 ports, used together with Type-E switch fabric modules
400G-QDD-DR4-SM1310
400G-QDD-FR4-SM1310
400G-QDD-ZR-SM1550
400G ZR transceiver, QSFP-DD form factor, Duplex LC, 1550 nm, 80 km (262,467.19 ft.) over SMF
400G-QDD-ZR+-SM1550
400G ZR+ transceiver, QSFP-DD form factor, Duplex LC, tunable wavelength, P2P distance of up to 120 km (393,700.79 ft.) over SMF
400G-QDD-SR8-MM850
100G AOC cable, QSFP28 form factor, 10 m (32.81 ft.)
25GBASE Series Optical Transceivers
25G AOC cable, SFP28 form factor, 5 m (16.40 ft.)
VG-SFP-SR-SM850
25G SR transceiver, SFP28 form factor, LC, 850 nm, 100 m (328.08 ft.) over MMF
25G LR4 transceiver, QSFP28 form factor, LC, 1310 nm, 10 km (32,808.40 ft.) over SMF
