RG-S5000-10GT2MS-P-E สวิตช์ - 1
RG-S5000-10GT2MS-P-E สวิตช์ - 2
RG-S5000-10GT2MS-P-E สวิตช์ - 3
RG-S5000-10GT2MS-P-E สวิตช์ - 4
RG-S5000-10GT2MS-P-E สวิตช์ - 5
RG-S5000-10GT2MS-P-E สวิตช์ - 6
RG-S5000-10GT2MS-P-E สวิตช์ - 7
RG-S5000-10GT2MS-P-E สวิตช์ - 8
RG-S5000-10GT2MS-P-E สวิตช์ - 9
RG-S5000-10GT2MS-P-E สวิตช์ - 10
RG-S5000-10GT2MS-P-E สวิตช์ - 11
2 x 1GE/2.5GE SFP ports
1 x RJ45 console port and 1 x USB port
System packet forwarding rate
27 Mpps
16 W (without PoE load)
141 W (full PoE load)
297 mm × 170 mm × 43.6 mm (11.69 in. × 6.69 in. × 1.72 in.)
Warranty
3 years
Applications
Local & Cloud O&M
Visualized Management
Alarm Processing
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
RG-S5000-24GT4MS-P-E
4 x 1GE/2.5GE SFP ports
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
27 Mpps
104 Mpps
27 Mpps
139 Gbps
64 MB
64 MB
64 MB
64 MB
64 MB
512 MB DDR4
512 MB DDR4
512 MB DDR4
512 MB DDR4
512 MB DDR4
256
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
2.0 kg (4.41 lbs)
2.40 kg (5.25 lbs)
3.70 kg (8.15 lbs)
3.60 kg (7.94 lbs)
3.18 kg (7.01 lbs)
4.13 kg (9.11 lbs)
Mounting
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
Fixed power supply: 16 W
Fixed power supply: 15.6 W
Fixed power supply: 30 W
Fixed power supply: 141 W
Fixed power supply: 430 W
16 W
33 W (without PoE load)
403 W (full PoE load)
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
27℃ (80.6°F): 40 dB
27℃ (80.6°F): 40 dB
27℃ (80.6°F): 40 dB
Air discharge: 8 kV/15 kV
Contact discharge: 6 kV/8 kV
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
RG-S5000-E Series
Port-based VLAN assignment
Basic QinQ and selective QinQ
DNS client
Neighbor Discovery (ND)
Expert ACLs
Port rate limiting
IEEE 802.1X authentication
Proxy ARP and ARP entry aging
Hardware CPP and NFPP
Load balancing modes
TFTP (TFTP client)
SSH v1.5/v2.0
Cloud
WIS
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
加载失败
TOP
