RG-IS5200-8GT4XS-UP-DC สวิตช์ - 1
RG-IS5200-8GT4XS-UP-DC สวิตช์ - 2
RG-IS5200-8GT4XS-UP-DC สวิตช์ - 3
RG-IS5200-8GT4XS-UP-DC สวิตช์ - 4
RG-IS5200-8GT4XS-UP-DC สวิตช์ - 5
RG-IS5200-8GT4XS-UP-DC สวิตช์ - 6
RG-IS5200-8GT4XS-UP-DC Industrial Ethernet Switch
RG-IS5200 Series
RG-IS5200 Series
RG-IS5200-8GT4XS
RG-IS5200- 8GT4XS-DC
RG-IS5200-24GT4XS-UP-DC
8x10/100/1000BASE-T ports
8 x 10/100/1000BASE-T ports
RS-485 Port
DIDO
1 x DI, 1 x DO
PoE-REP
RG-IS5200-8GT4XS
72Mpps
72Mpps
72Mpps
96 Gbps
96 Gbps
96 Gbps
1GB DDR4
PoE-REP
4Gbps
RG-IS5200-8GT4XS
150mm x 133mm x 86mm
442mm x 220mm x 43.6mm
1.49kg
1.5kg
1.53kg
2.85kg
installation method
PoE-REP
RG-IS5200-8GT4XS
Power connector type
Terminal block
Not Supported
● Rated current:0.6A
● Rated voltage:240V DC
● Rated current:0.3A
● Rated current: 2 A to 0.5 A
110 V AC:16.7W
220 V AC:16.8W
240 V AC:16.8W
12 V DC: 19.8W
48 V DC: 17.5W
Leakage current
≤3.5mA
Terminal block
● Rated voltage: 56 V DC
● Maximum voltage:
PoE only: 48 V DC
● Rated current: 10 A
PoE not supported: 12 V DC
PoE only: 48 V DC
23.8W (Without PoE)
503.8W (full PoE load)
12V DC input: 36.8W
56V DC input:
● 35.5W (Without PoE)
● 515.5W (full PoE load)
PoE budget: 480 W
PoE budget: 480 W
PoE distance
PoE-REP used:
Ports 5 to 8:
PoE-REP used:
Ports 21 to 24:
PoE-REP
PoE Powered (Input)
PoE power (output)
RG-IS5200-8GT4XS
IP rating
IP40
AC power port:
Service ports:
DI/DO/RS-485 port:
Service ports:
DI/DO/RS-485 port:
Conducted immunity
Performance criterion: A
AC power port: 3 V
Service port: 3 V
DI/DO/RS-485 port: 3 V
AC power port: 3 V
Service port: 3 V
Voltage dip
AC power port:
Vibration
Shock
IEC61000-3-3,GB17625.2
European Limits
PoE-REP
IP rating
10 kV
RG-IS5200-8GT4XS
RG-IS5200 Series
ND and ND snooping
Multiple AAA modes
 TACAS+
REUP, RLDP, and DLDP
Dual-boot redundancy
Fan fault alarming
Virtualization
SPAN, RSPAN
SNMPv1/v2/v3
RMON (groups 1, 2, 3, and 9)
RG-IS5200-8GT4XS
Built-in AC power supply, single AC power input, fanless design, IP41 (supporting upgrade to IP55), DIN rail mounting
RG-IS5200-
8GT4XS-DC
Dual DC power supplies, supporting 60 W power input through the IPA60 power adapter, fanless design, IP41 (supporting upgrade to IP55), DIN rail mounting
RG-IS5200-
8GT4XS-UP-DC
8 x 10/100/1000BASE-T ports, PoE/PoE+/PoE++ power supply, 4 x 1GE/10GE SFP+ ports
Dual DC power supplies, supporting 240 W power input through the IPA240-P power adapter, fanless design, IP41 (supporting upgrade to IP55), DIN rail mounting
RG-IS5200-
24GT4XS-UP-DC
24 x 10/100/1000BASE-T ports, PoE/PoE+/PoE++, 4 x 1GE/10GE SFP+ ports
Dual DC power supplies, supporting 60 W power input (without PoE) through the IPA60 power adapter or 240 W power input (with PoE) through the IPA240-P power adapter, fanless design, IP40, mounting in a 19-inch rack
IPA240-P
240 W AC PoE power module, applicable to RG-IS5200-8GT4XS-UP-DC and RG-IS5200-24GT4XS-UP-DC (PoE scenarios), supporting 1:1 hot standby (not simultaneous power supply), IP40, DIN rail mounting
IPA60
60 W AC power module, applicable to RG-IS5200-8GT4XS-DC and RG-IS5200-24GT4XS-UP-DC (non-PoE scenarios), supporting 1:1 hot standby (not simultaneous power supply), IP40, DIN rail mounting
Accessories
PoE-REP
IS52-shield
IP55 protective enclosure, applicable to RG-IS5200-8GT4XS, RG-IS5200-8GT4XS-DC, and RG-IS5200-8GT4XS-UP-DC
GE-SFP-SR-MM850-I
GE-SFP-LR-SM1310-I
XG-SFP-SR-MM850-I
XG-SFP-LR-SM1310-I
