บ้าน> ผลิตภัณฑ์> สวิตช์ > สวิตซ์ Bare Metal>
B6520-64CQ Switch
The Ruijie B6520-64CQ switch is a new generation high density 100GbE switch designed for cloud-scale datacenter and campus networks, which provide a powerful cache capacity and advanced scheduling mechanism driven large scale line-rate non-blocking network.
B6520-64CQ provides 64-port backward-compatible 100GbE QSFP28 interface to transparently migrate existing data center fabrics from 40Gbps speeds to 100Gbps. The platform provide hot-pluggable 1+1 redundancy power module and 2+1 redundancy cooling fan module to meet the high reliability requirement of datacenter and carrier networks.
NOTE:
Ruijie B6520-64CQ is a bare metal switch hardware system with Open Network Install Environment (ONIE). Customer should install networking operation system before use, or contact Ruijie Networks co. for OS support.
More+
Performance
  • 64 × QSFP28 100GbE Ports
  • Base on Broadcom BCM56970 (Tomahawk II)
  • Flexible 100GbE, 40GbE support
  • Up to 12.8 Tbps (full duplex)
  • Up to 4400 Mpps
  • Wire speed L2 and L3 forwarding
  • Latency from 1137ns for 100GbE (cut-through mode)
Data Center Optimized Design
  • Typical power of under 4.5W per 100GbE port
  • Over 94% efficient power supplies
  • 1+1 redundant & hot-swappable power
  • 2+1 redundant & hot-swappable fans
  • Front-to-rear cooling
  • Tool less maintenance and simple installation
Cloud Networking Ready
  • 128 ECMP for hyper-scale networks
  • Dynamic Load Balancing for advanced multi-pathing
  • Advanced Congestion Management for NVMe and AI workloads
  • Flow aware traffic scheduling
  • Shared 42MB Buffer with burst absorption
  • Up to 264K MAC and 128K Host entries
  • Over 384K IPv4 Routes
  • Over 128K IPv6 Routes
Resilient Control Plane
  • Intel Xeon D-1527 Processor (Formerly Broadwell DE)
  • 8GB DRAM
Switch Model
B6520-64CQ
64×QSFP28
Max100/40GbE Ports
Throughput (full duplex)
12.8Tbps
Packets/Second
4400Mpps
Latency (cut-through mode)
1137ns
Intel Xeon D-1527
System Memory
8GB (Up to 32GB)
System Storage
≥64GB
BMC Option
Switch ASIC
Broadcom BCM56970(Tomahawk II)
Packet Buffer Memory
42MB (Dynamic Buffer Allocation)
10/100/1000 MGMT Ports
RS-232 Serial Ports
1 (RJ-45)
USB Ports
Hot-swap Power Supplies
2 (1+1 redundant)
Hot-swappable Fans
3 (2+1 redundant)
Airflow Option
(Forward and Reversed airflow)
Typical/Max Power Draw
610W/785W
Typical/Max Heat Dissipation
2081.41/2678.53 BTU/hr
Size(W×H×D)
17.32×3.39×22.83 in.
(440×86×580mm)
38.5 pounds (17.5kg)
Power Supplies
800W
Standard Compliance
EMC
Emissions: FCC, EN55022, EN61000-3-2, EN61000-3-3 or EN61000-3-11, EN61000-3-12 (as applicable)
Immunity: EN55024
Emissions and Immunity: EN300 386
UL/CSA 60950-1, EN 60950-1, IEC 60950-1 CB Scheme with all country differences
Certifications
North America (NRTL)
European Union (EU)
BSMI (Taiwan)
C-Tick (Australia)
CCC (PRC)
MSIP (Korea)
EAC (Customs Union)
VCCI (Japan)
European Union Directives
2006/95/EC Low Voltage Directive
2004/108/EC EMC Directive
2011/65/EU RoHS Directive
Power Supply Specifications
800W
Input Voltage
100-240V AC
240V DC
Typical Input Current
10-5A (AC)
4.5A (DC)
Input Frequency (AC)
50~60Hz
Input Connector
IEC 320-C13
Efficiency (Typical)
94% Platinum
Environmental Characteristics
32 to 113° F (0 to 45°C)
-40 to 158° F (-40 to 70°C)
Relative Humidity
5 to 95% non-condensing
Altitude (Operating)
Designed to meet: 0 to 10,000ft
Altitude (Non-operating)
-1000ft to 30,000ft
B6520-64CQ
64 fixed 100G QSFP28 ports.
3 slots for fan modules.
2 power supply modules and 3 fan modules already included.
M6520-FAN-F
Fan module, front-to-rear airflow.
With up to 3 fan modules, support 2+1 redundancy.
RG-PA800I-F
AC power supply module, front-to-rear airflow.
With up to 2 power modules, support 1+1 redundancy.
Ruijie Networks
