บ้าน> ผลิตภัณฑ์> สวิตช์ > สวิตซ์ Bare Metal>
B6510-48VS8CQ Switch
The Ruijie B6510-48VS8CQ is a new generation high performance and high density 25GbE switch designed for cloud-scale datacenter and campus networks, which provide a powerful cache capacity and advanced scheduling mechanism driven large scale line-rate non-blocking network.
B6510-48VS8CQ introduces 48-port fully backward-compatible 25GbE SFP28 interface and 8-port 100GbE QSFP28 interface to transparently migrate existing data center fabrics from 10Gbps and 40Gbps speeds to 25Gbps and 100Gbps. The platform provide hot-pluggable 1+1 redundancy power module and 3+1 redundancy cooling fan module to meet the high reliability requirement of datacenter and carrier networks.
NOTE:
Ruijie B6510-48VS8CQ is a bare metal switch hardware system with Open Network Install Environment (ONIE). Customer should install networking operation system before use, or contact Ruijie Networks co. for OS support.
More+
Performance
  • 8 × QSFP28 100GbE Ports & 48 × SFP28 25GbE Ports
  • Base on Broadcom BCM56873 (Trident III)
  • Flexible 100GbE, 40GbE, 25GbE and 10GbE support
  • Up to 4.0 Tbps (full duplex)
  • Up to 2003.4 Mpps
  • Wire speed L2 and L3 forwarding
  • Latency from 814ns for 25GbE (cut-through mode)
Data Center Optimized Design
  • Typical power of under 4W per 100GbE port and 1.5W per 25GbE port
  • Over 94% efficient power supplies
  • 1+1 redundant & hot-swappable power
  • 3+1 redundant & hot-swappable fans
  • Front-to-rear cooling
  • Tool less maintenance and simple installation
Cloud Networking Ready
  • 128 ECMP for hyper-scale networks
  • Dynamic Load Balancing for advanced multi-pathing
  • Advanced Congestion Management for NVMe and AI workloads
  • Flow aware traffic scheduling
  • Shared 32MB Buffer with burst absorption
  • Up to 288K MAC and 168K Host entries
  • Over 344K IPv4 Routes
  • Over 96K IPv6 Routes
Resilient Control Plane
  • Intel Xeon D-1527 Processor (Formerly Broadwell DE)
  • 8GB DRAM
Switch Model
B6510-48VS8CQ
48×SFP28 + 8×QSFP28
Max 100/40GbE Ports
Max 25/10GbE Ports
Throughput (full duplex)
4.0Tbps
Packets/Second
2003.4Mpps
Latency (cut-through mode)
814ns
Intel Xeon D-1527
System Memory
8GB (Up to 32GB)
System Storage
≥64GB
BMC Option
Switch ASIC
Packet Buffer Memory
32MB (Dynamic Buffer Allocation)
10/100/1000 MGMT Ports
RS-232 Serial Ports
1 (RJ-45)
USB Ports
Hot-swap Power Supplies
2 (1+1 redundant)
Hot-swappable Fans
4 (3+1 redundant)
Airflow Option
(Forward and Reversed airflow)
Typical/Max Power Draw
258.9W/301.0W
Typical/Max Heat Dissipation
883.6/1027.3 BTU/hr
Size(W×H×D)
17.40×1.73×22.04 in.
(442×44×560mm)
22.7 pounds (10.3kg)
Power Supplies
550W
Standard Compliance
EMC
Emissions: FCC, EN55022, EN61000-3-2, EN61000-3-3 or EN61000-3-11, EN61000-3-12 (as applicable)
Immunity: EN55024
Emissions and Immunity: EN300 386
UL/CSA 60950-1, EN 60950-1, IEC 60950-1 CB Scheme with all country differences
Certifications
North America (NRTL)
European Union (EU)
BSMI (Taiwan)
C-Tick (Australia)
CCC (PRC)
MSIP (Korea)
EAC (Customs Union)
VCCI (Japan)
European Union Directives
2006/95/EC Low Voltage Directive
2004/108/EC EMC Directive
2011/65/EU RoHS Directive
Power Supply Specifications
550W
Input Voltage
100-240V AC
240V DC
Typical Input Current
7.2-3.5A (AC)
3.6A (DC)
Input Frequency (AC)
50~60Hz
Input Connector
IEC 320-C13
Efficiency (Typical)
94% Platinum
Environmental Characteristics
32 to 113° F (0 to 45°C)
-40 to 158° F (-40 to 70°C)
Relative Humidity
10 to 90% non-condensing
Altitude (Operating)
Designed to meet: 0 to 5,906ft
Altitude (Non-operating)
-1640ft to 16,404ft
B6510-48VS8CQ
48 fixed 25G SFP28 ports, 8 fixed 100G QSFP28 ports.
4 slots for fan modules.
2 power supply modules and 4 fan modules already included.
M6510-FAN-F
Fan module, front-to-rear airflow.
With up to 4 fan modules, support 3+1 redundancy.
RG-PA550I-F
AC power supply module, front-to-rear airflow.
With up to 2 power modules, support 1+1 redundancy.
Ruijie Networks
